Rev limiter and boost?
Old Oct 9, 2002 | 09:13 PM
cdk4219's Avatar
Default Rev limiter and boost?
How bad is it to hit the rev limiter on boost? the reason I ask is that with 4.10 gears and a 6 speed I tend to do this every once in a while.
Old Oct 10, 2002 | 05:44 AM
smokinHawk's Avatar
Default Re: Rev limiter and boost?
Hopefully not to bad.
Ive wacked it a few times on my set up at Norwalk.
And its set at 6500
<small>[ October 10, 2002, 05:44 AM: Message edited by: smokinHawk ]</small>
Old Oct 10, 2002 | 06:58 AM
cablebandit's Avatar
I dont know how bad it is but it's not a good idea. I say this because the ls1 cuts off the fuel at the rpm limit.....no fuel is NOT what you want with forced induction. Probably doesnt hurt just to bump it tho. I hit mine a lot when it spins in first because it revs so quickly
Old Oct 10, 2002 | 08:40 AM
Black LS1 T/A's Avatar
Moderator
I've heard it said one guy damaged his A4 doing this consistently, as well. Either drop the shift point (1st gear is usually the culprit) or raise the rev limit, if you dare. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 10, 2002 | 10:27 AM
99GMC Can's Avatar
I'm with Cablebandit. Rev limited by lack of fuel in force induction is very bad! But, maybe since all the fuel is cut it's not at bad as just going lean. Sounds dangerous though
