How to Test for Vacuum or Induction Leaks
Old Oct 14, 2005 | 08:14 PM
cincyrider's Avatar
Default How to Test for Vacuum or Induction Leaks
Found this today and figured I had to post it here. Pretty neat idea!
I just might have to make one of these.
How to build an Intercooler Pipe Pressure Leak Tester
Parts Needed:
A 4 inch long piece of 2.5" O.D. (outside diameter) hose. (I used some radiator hose I got at NAPA)
1.5" I.D. (inside diameter) PVC end cap.
2 band clamps that will fit around the 2.5" pipe above.
A valve stem (I used the rubber type you press in)
Note that if you have a larger turbo, the sizes of the end cap and hose may need to be larger in order to fit the turbo inlet.
[IMG]To assemble, just put everything together as shown.[/IMG] Pic on Left
[IMG]To assemble, just put everything together as shown.[/IMG] Pic in Middle
[IMG]To get the valve stem in, I had to drill a hole in the PVC cap.[/IMG] Pic on Right
To use it, just remove the intake pipe from your turbocharger inlet, and attach this in its' place.
Now you need to hook something up to the valve stem to pressurize the intake so you can listen for leaks. I use a 7 gallon air tank I got from Walmart, I just fill it up with air at the local gas station. You can also use a simple bike pump.
If you have a manual boost controller hooked up, you might want to plug off its' intake hose, as they leak a lot of air, making it hard to pinpoint the real leak.
Pressurize the system, and listen all over for leaks. Make sure you or a friend listens under the bumper too, wherever there is IC piping.
A leak will be obvious, they make a loud hissing sound.
You might want to have a friend check out your boost gauge while you are pressurizing things, to make sure you don't put too much pressure on things. (20 psi should be safe, or whatever you run safely for boost)
Places I have heard of leaks occuring:
BOV flange
Intake manifold ports
Throttle Body gaskets
Holes in the intercooler
Holes in the intercooler piping (sometimes the rubber pipe inside the stock woven mesh pipes cracks, and you can't see it from the outside... the pressure tester will find it though!! )
Pictures and Text by Brent Cook
Idea for tester from Josh Wingell
Contact bacook@mediaone.net for questions.
Attached Thumbnails How to Test for Vacuum or Induction Leaks-ptesterangle.jpg   How to Test for Vacuum or Induction Leaks-ptesterside.jpg   How to Test for Vacuum or Induction Leaks-ptestertop.jpg
