Procharger headers
Old Oct 15, 2005 | 03:20 PM
paulcars's Avatar
Default Procharger headers
I have an Procharged LS-! with a small cam and ported heads with LT headers and aftermarket cats. I live in CA and am thinking of putting the stock exhaust manifolds and cats back on. Any idea of HP loss?
Old Oct 15, 2005 | 08:40 PM
Chas1's Avatar
I was running 381 rwhp, 368 rwtq with just a P1SC1 at 5lbs with the FMU, completely stock otherwise except for the borla.
Old Oct 17, 2005 | 06:22 AM
EPP's Avatar
EPP
Unless you add a larger blower pulley, your boost will go up once you swap out to the manifolds and cats. With the increase in boost, I doubt you will see much of a power loss. I'd check your air/fuel ratio once you have done the swap, just to make sure your combination is still safe. Bob
