Kenne-Bell Boost-a-pump, Others?
Please list your voltage booster & fuel pump type.
Please list your PSI results and what products you recommend as well as source & pricing.
Are you boosting voltage at all times or is it boost regulated?
Thanks!
Do you run the BaP at all times or is it boost referenced? What kind of regulator are you using?
It is boost referenced.
