vortech guys using a canton oil pan
Old Nov 12, 2002 | 12:38 AM
96SCTA's Avatar
Default vortech guys using a canton oil pan
Any you guys runnig this type of oil pan. I have just recently installed it on my block. The only thing is that i do not want to tap into the new pan for the oil line for the blower. But i did notice that the oil pan has some type of screw plug on the oppoist side of the oil filter. I think that could be used for the oil return line from the blower. any you guys have any input on this. Also when you tap into the oil pan on the stock oil pan they have you do it at the right hight on it so the oil will drain back (gravity feed) but this new oil pan is alot dirrerent than the stock one. SO i do not know were to tap. I would like to avoid it all together and just use the screw plug hole like i mentioned.
