What do I have to do to get an ATI D1 supercharer?
Old Nov 24, 2002 | 06:51 PM
andyws6's Avatar
Default What do I have to do to get an ATI D1 supercharer?
Hey guys,
I really would like to get an ATI procharger but I really don't know a whole lot. I would get the 42lb. injectors and in-line fuel pump with the ATI and a 10 lb. pulley belt all from tbyrne. Do I have to reprogram my ECM? If so should I mail it off to Ed Wright or do it myself with LS1 edit? Again, I don't know much so could someone like me even operate ls1edit? I am planning on purchasing within the next couple of days so any help and/or suggestions would be GREATLY Appreciated! Thanks, -Andrew 99 Trans Am WS6
Old Nov 25, 2002 | 01:47 AM
LS1Bird's Avatar
Default Re: What do I have to do to get an ATI D1 supercharer?
Andrew, using your own assessment "I don't know much about all this", that would be reason enough to NOT try and do LS1Edit tuning yourself. It would be better to send out for it, and then get your car to a dyno that does wideband (A/F, O2's) to see if it is right. A little bit of detonation goes a LONG way on a boosted engine.
I'm getting my D-1SC installed soon (using pretty much the same combo you mentioned), and I'm having it all done at Force Fed Performance, installing/tuning/dyno/everything. I can't wait!
www.californiamasseys.com/formula.html
Mike M
