Learn me something...tubular manifolds vs ??????
Cast =
Cast is generally heaver, but requires less maintence/monitoring. Tubular is, in theory, more desirable, but turbo support and manifold construction must be correct, else cracked welds may well be a problem. Tubular is also (generally) considered to be more expensive, given the number of used production LSx manifolds floating around.
I'm using 6.0 manifolds on my turbo project.
Think that covers everything. What did I win?
Cast =
To sum up the differences basically, smoother transitions, lighter weight, better flow properties in most cases. The tubular though has the advantage of lasting forever.
JZ
JZ
Thought that was interesting.I suggest reading the Turbo FAQ at the top of this forum Quickin. And yes the turbo's mount to the end of the manifold. Are you just comparing tubular to cast? We should not forget to mention a Log type setup. This setup is particularily controversial due to higher back pressures from poorly routed exhaust gases. Do a search as well, there is alot of discussions about log setups, cast truck manifolds, remote mounted (sts), and custom/sponsor manifold setups.
CMC
I ran 10.50 @ 137 in a 3800 lb car om pumpgas. Ahould mae about 700 hp to the wheels.
Whats the dyno numbers?
Looks friggin great man!
Now I'm well informed what tubular and cast means, and more importantly I now what parts are associated with being tubular and/or cast that makes a kit better than the other.
This site, which is why it's here, did its job. I'm now better informed.
