Homemade ls1 turbo?
Old Oct 20, 2005 | 02:16 AM
530transam's Avatar
Default Homemade ls1 turbo?
has anyone ever done a do it your self homemade turbo kit for an ls1?like at homemadeturbo.com they tell you how to do a turbo for a civic for around $500 and my buddy did it with his 99 ex and it work great!ive never felt a honda pull like that!hes been over 40,000 miles since the install two years ago and no problems it even smoggs.im very interested in doing a kit like this for my 99 trans am or id like even more to do a twin turbo.however,ive never seen anything like this on the3 net for a trans am and without a guide like this one im pretty cluless.i wouldnt know which turbo to buy off what car and how to do everything.or can anybody whip up a similar guide? using recycled or quality junkyard parts.on my buddys civic for the most part it was 95-99 eclipse parts.id really appreciate this if anyone can help out!
Old Oct 20, 2005 | 05:18 AM
smokinHawk's Avatar
one thing is you get what you pay for.
finding junk yard turbos that can suplly the ls1 with enough air is hard, most just go and buy a good turbo for their needs.
Masterpower turbos are cheap turbos that can push enough air to feed the ls1.
a few of us have made a home set up do a search for 6.0 manafolds or truck manafolds and you can find some info on it.
others have went the dy route with an sts style, might be cheaper that way but it wont perform as well.
Old Oct 20, 2005 | 06:50 AM
Assassin's Avatar
unless your a good welder, great fabricator, and have access to a wide array of tools, this may not be the project for you, you may be very dissapointed at the outcome, also you would need at least 3k to even come close to getting it running right, dont forget about the tune, fuel system, gauges, and intercooled is a must on 10:1 compression, thats if you dont need anything else for your engine before or after you go into boost, ie pushrods, valvesprings, internal engine parts, ect.... the parts add up very quickly.... if you have a spare beater vehicle that you dont mind rolling off a cliff, it might be wise to give a go on that first... you can allways sell it as a turbo car if it ends up working out and get some $$ back, the learning experience will be invaluable...
Old Oct 20, 2005 | 07:19 AM
96 Comp T/A's Avatar
It could be done, although not for $500 dollars. An LS1 is not the car to be your first turbo build. The motor architecture in it's stock form is very unforgiving (cast pistons, high compression, expensive electronics) with all that being said you can make tons of hp with a properly built turbo install, I would look at all the kits available to get ideas on how you want to handle piping, read up on turbocharger theory (it's all over the net and can also be found at reputable book stores) and then do some searches here for some more knowledge.
Old Oct 20, 2005 | 10:10 AM
black_z's Avatar
Dont let these guys discourage you from trying it on your own. Im going to start the install next winter, im just collecting parts right now. If you go with 6.0 manifolds it really doesnt require "that much" fabrication. Just keep researching and you will learn a lot. I picked up "Maximum Boost" by Corky Bell. Its a GREAT read to get you to understand the theory behind turbocharging, and how everything works.
Old Oct 20, 2005 | 10:11 AM
black_z's Avatar
Although the LS1 isnt a very forgiving engine for a first turbo build, its not that bad of a platform to start out with. A good tune, and plenty of fuel will keep the motor living for quite a while.
Old Oct 20, 2005 | 10:12 AM
Z284U2TRY's Avatar
search for riceaters posts he built his own kit but he knows his stuff. You can get some good ideas from the pictures.
