Detuning?
Old Dec 20, 2002 | 06:53 PM
superchargedZ's Avatar
Default Detuning?
Has anyone took their blower off(or belt) and tuned it back to stock? One of buddy's wants to race me with no blower. So, I am going to take the belt off and run him. So, I know I have to scale the injectors for 38lb I would also need to adjust the PE table. Should I put the PE table to stock 1.2403 and bump the timing to 30*?
Thanks Jason
Old Dec 20, 2002 | 11:12 PM
1dirtyZ's Avatar
Default Re: Detuning?
what ever you do, don't forget to remove the the metal manifold infront of the throttle body, if you keep it , your car will run like a turd.
what happened to your stock tunning??( didn't you save it?)
Old Dec 21, 2002 | 12:03 AM
What is the metal manifold you are speaking of?
I have the stock file...but all I was going to change is the timing(raise it) and the PE vs RPM table.
