The beginning of something...
A nice fresh deep-panned th400 with a TCI RMVB and a brake
I have the crossmember, shifter, madman dipstick, steel driveshaft, hefty 2800 stall (looking for more under boost though
) .... all I need is the TCI flexplate, cooler, and I think a spacer for the stall. I have a 12-bolt (not in the car yet) but I need to get the 3.73s swapped out for some nice 3.08s. I'm hoping this combo will work well on the track and the gear and tight stall will make it a liveable setup for the street. It's not my daily driver but it'd be nice to retain that kind of usefulness.
What was that post all about?
Got more goodies
The new ring and pinion for the 12-bolt, tranny cooler, tranny shield, TCI flexplate, a cutout, and some ARP hardware.... and one toy robot courtesy of FANUC. I changed my mind about the shifter too, went with a quick silver, it was a favorite of mine when I was first driving.
So... an update I guess.
I've been out of town for a week for work; I'll be home through the weekend but go back out for a different job this coming week. The last 2 months I've seen ridiculous deadlines at work with long hours and lots of stress, and I don't seem to handle the stress as well these days, so the car needs some attention.
My turbo kit has liberated my driver's side motor-mount, and I have no idea how to even get to it without taking most of the kit off ( https://ls1tech.com/forums/forced-induction/670029-ptk-pts-owners-tubular-k-members-inside-please.html ), since most of it is on that side. I also have to find a solution for the boiling of the power sterring fluid that the kit has blessed me with as well as burning up some plastic part of the steering shaft which has caused play in the wheel. When I get back home a nice set of Spohn solid mounts will be waiting, as well as my HPTuners unlimited GenIII USB Pro upgrade
I've really been into this tuning schizzy as of late (for other folks that is)...Since I am just action-packed with issues, outside of my motor mount, here's the latest: I buy a 12-bolt with under 2K miles from a user here. He says it makes some noise but hasn't heard another to compare it to really. They all make some noise, so I wasn't worried. It's a moser, 33 spline axles, 4ch all setup to go, 3.73. Since I want to keep this th400 streetable and let my turbo "work" it's tq magic, a 3.08 seemed to be a no-brainer. The carrier cut-point was 3.73 and numerically lower, so I should have been fine. The shop setting up the ring and pinion calls me... the rear has a broken spider gear. The user I got it from (OVER A YEAR AGO!) actually sent me some money back to help out, which I didn't expect and is great. Turns out on the Eaton carrier I can't get just a top gear, I have to get all of them and the plates and springs too. There goes another 180+65 labor. They rebuild the carrier (already have the pinion in) and find out that the 3.73 must be a FOUR SERIES ODD GEAR, cuz that 3.08 is NOT gonna work out.
The only option at this point is MORE labor $$ and freakin $500 carraige or just have him re-install the 3.73 and sell the thing taking a loss on the work done.Since the driveshaft for the th400 fits the 12-bolt, I can't do the tranny without a rear-end to go in. I need to get the Wolfe 6-pt in the car still also.
I have a LOT to do before it sees the track and I don't have much free time. I live in an apartment right now too, so I have to arrange work at my friend's locations (sorry guys
) and not wanting to have to leave it on their property (don't want to inconvenience them) over night is making it VERY VERY tough to see through.More time, more money
Kyle
...My turbo kit has liberated my driver's side motor-mount, and I have no idea how to even get to it without taking most of the kit off ( https://ls1tech.com/forums/showthread.php?t=670029 ), since most of it is on that side. I also have to find a solution for the boiling of the power sterring fluid that the kit has blessed me with as well as burning up some plastic part of the steering shaft which has caused play in the wheel. When I get back home a nice set of Spohn solid mounts will be waiting, as well as my HPTuners unlimited GenIII USB Pro upgrade
The only option at this point is MORE labor $$ and freakin $500 carraige or just have him re-install the 3.73 and sell the thing taking a loss on the work done.............
Well, with the help of some good friends in RPM, I got the motor mounts swapped out for a set of Spohn solids that feel NICE. I got the play out of my steering that I THOUGHT was from the kit, turns out it was loose hardware just above the rack. It was a good day.
...just had to use fart.
