ideal compresion?
Old Dec 30, 2002 | 08:59 PM
parish8's Avatar
single digit dreamer
Default ideal compresion?
i am going to be geting some forged pistons soon and am wondering if i should drop the compresion some? and if so how much.
stock is 9.4-1, i can only run 6-7psi now before detonation sets in. the blower has the capasity to run 10+psi on my current set up so if i droped the compresion i would be able to up the boost.
i have no intercooler and may hit it with some nitrous in the future if that makes any diference. 92 octane also.
Old Dec 30, 2002 | 09:57 PM
parish8's Avatar
Default Re: ideal compresion?
after doing a search i see 9-1 is a common ratio so now my question is since i have a blower that makes instant boost at low rpm's would that change the acepted 9-1 ratio at all?
i am told lightings run 8.5-1, i will probably stick with the 9-1 unless someone on here thinks it should be less.
Old Dec 31, 2002 | 04:03 PM
smokinHawk's Avatar
i chose 9.0:1 on my street/track car.
with the lower CR the more boost you can run, but loose throttle response and streetabilty, i think 9:1 is just right for a turbo car on the street, not to laggy but able to run some good boost.
for notes Y2K hawk (harlan) has his 700rwhp beast at 8.5:1 CR
and Cablebandit (Jerry) had his 580 rwhp beast at 8.9-8.7:1
Old Jan 4, 2003 | 07:32 PM
BigTex's Avatar
I think 9:1 would be a fine choice. I think thats a good choice. Once you drop compression, you will lose a little boost. Meaning it will take a smaller pulley to maintain the same amount of boost you are currently running. Instead of seeing 6-7, you will probably see 5-6 with the existing pulley.
BTW - I like your idea of entering PE earlier.
Old Jan 4, 2003 | 07:40 PM
VINCE's Avatar
Shorty Director
Your case sounds more like tuning.. I know of several blower guys with 10.1:1 compression running 9#'s with no problems..
Old Jan 4, 2003 | 07:42 PM
parish8's Avatar
no intercooler may have something to do with it also but yes it needs to be tuned with a wideband
