installing intake walbro pump on 2000 t/a
http://www.ls1.com/forums/showthread...hreadid=216968
I used my old stock pump outer shell to make the Walbro fit in the rubber sock perfect. I'm also going to install a relay on my pump which will help it pump more.
just make sure you TIGHTEN THE **** out of the hose clamps from the pump to the top of the module ( i used 2 clamps on each end).
