supercharged
Old Oct 24, 2005 | 12:25 AM
electricz28's Avatar
Default supercharged
I am treading into unknown territory all. I need some direction for the rest of my build. I have a 224/112/581 cam with 1"7/8 kooks and the LS6 intake w/ported TB. Stock bottom end and heads with less than 50K miles on the clock. Stage 1 4L60e with 3200 stall going to 3.73 gears
What heads should I get to lower my compression to get the most out my set up when I get the supercharger.
Old Oct 24, 2005 | 05:37 AM
EPP's Avatar
EPP
Check out the Patriot Performance Stage 2 and Stage 3 LQ9 heads. We use them for most of our builds, and have had great results. Bob
Old Oct 24, 2005 | 08:33 AM
UnderPSI's Avatar
Those are the same heads that I am running, I am really happy with them.
Old Oct 24, 2005 | 09:42 AM
Gunnar@Patriot's Avatar
Our LQ9 heads would be a great choice for this set up. Give the guys at Exotic a call, they can fix you up.
