Help with pistons
Old Jan 12, 2003 | 01:15 PM
ZYA_LTR's Avatar
Default Re: Help with pistons
I have DIAMOND pistons in mine, and have no problems, we use them at the shop, in all kinds of motors, from 4.3 v6 s-10's to 572 ci offshore race boat motors, no problem, the pistons fit fine, as long as you machine the bore to fit the piston, don't just slap them in.
Old Jan 12, 2003 | 03:24 PM
StupidFast's Avatar
I was just goning to hone the bore and slap some standard bore pistons in. You recommend boring the block? All the barrels look good.
Old Jan 12, 2003 | 04:30 PM
ZYA_LTR's Avatar
No, that's what i mean, have the block machined(honed, for the pistons) we went with Diamond 3.9005 bore pistons, and they fit great as long as you machine the block for the pistons.
Old Jan 13, 2003 | 12:09 AM
StupidFast's Avatar
Default Help with pistons
I just got my Eagle h-beam rods last week and now I am looking for pistons. I would like my compression to be 9.2ish with a set of LS1 heads.
This will be a LS1 motor swap fo my pickemup.
My buddy said that he is not a big fan of Diamond pistons. He was real big into those little Buick V-6 turbos, 5.98 in the 1/8. He said that all the Diamonds he has installed have a little to much bore clearance for his taste. I was wondering if anyone else have used these pistons? If no, what pistons would you use?
Thank you for your responses.
Old Jan 13, 2003 | 05:48 AM
smokinHawk's Avatar
i used JE pistons with eagle rods.
