Paging all Water/Alky injection guys
I have a few Qs for you on Water/Alky injection.
What size tank are you using?
How long does the typical tank last in spirited driving?
Do you mount the tank in the spare tire area and run the lines forward?
Are you just using a small inline pump to feed the nozzles?
How are you triggering it? WOT switch or something more complicated?
What mix of water alky are you using?
How much extra timing can you run with this setup?
Is tuning more difficult or easier with this setup
Do you save much weight using this setup over a tradition Air to Air intercooler system with all its associated tubing?
I think this could be a great setup if you had a plastic cell run from the spare tire well (Better traction <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> ) with inline bosch pump or similar with braided lines running up to the injector plate and some form of switch to activate it.
Thanks for any advice you can give <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Chris
If you fab your own you have to tailor the flow rate to your car somehow. It's not impossible, but it is long, laborious and tedious to keep ripping up the system until you have it right, plus you can't just turn it up when you want.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">How long does the typical tank last in spirited driving?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">uses 36 oz per minute.
A tank lasts around ten- 10 second wot runs.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Do you mount the tank in the spare tire area and run the lines forward?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I run my system up front where the battery was.
This allows for short lines and non pressuerized lines when not needed.Less than 1 sec from start of pump to full flow and pressure.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Are you just using a small inline pump to feed the nozzles?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Shurflow pump 1.4gpm, 3 nozzles @ 100psi for superior atomization
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">How are you triggering it? WOT switch or something more complicated?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">wot switch. Supercharged, no need for any boost switch.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">What mix of water alky are you using?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">50/50 mix denatured alcohol/water. For serious runs- 50/50(90/10)water/methanol/acetone
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">How much extra timing can you run with this setup?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">8 degrees and a 100 degree drop in charge temp.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Is tuning more difficult or easier with this setup</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">with ls1edit and a wideband it's very easy to tune.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Do you save much weight using this setup over a tradition Air to Air intercooler system with all its associated tubing?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">my entire system is around 6lbs.
Steve
lasts for months, I get into boost everytime I drive but I do only drive the car 2-3 times a week if that.
I too was able to run 8 more degrees timing
Same pump as Steve.
I use a pressure switch to activate it.
50/50 water/denatured
I have an in-car wideband and ls1-edit so tuning is no problem
