Overall sheet metal FI intake design
Now considering and LS1 here...
1. Is a large plenum really required here?
2. What about dual throttle bodies linked together with a long tube design which runs seperately to each bank? Similar to headers.
3. Doesn't the intercooler act as a plenum of sorts? Or is balance an issue?
4. Is heat soak an issue with a sheetmetal intake if it's insulated (coated)?
5. What would be the best design?
1. Is a large plenum really required here?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">For a turbo motor I was told I needed a larger one (forget the exact size plunum they wanted to use per ci... Think it was like 1.5 per ci or something like that.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 2. What about dual throttle bodies linked together with a long tube design which runs seperately to each bank? Similar to headers.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I did the dual throttle bodies cause I liked the look and was originally looking at dual runners(two seperate sides) After talking to Hogans about this they said do not do it that actually from one large plenum it was better. Said it had been tested back to back
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 3. Doesn't the intercooler act as a plenum of sorts? Or is balance an issue?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't believe so as it is not right at the intake port to draw air from.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 4. Is heat soak an issue with a sheetmetal intake if it's insulated (coated)? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 5. What would be the best design? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I like the single large plenum, with a single large throttle body. I am using Accufab t/b with a conversion to a gm style sensors. I would give Hogan racing a call and talk over with them. They are really good about info.
Steven
