Engine/head Removal W/ Incon Kit
I've disassembled the upper half, manifold, rad, and all the accessories. Pulled the rockers and pushrods and loosened the manifold bolts.
But what I don't know is if I can remove the heads without taking the turbos out. I don't have the stock K member so they won't rest on that.
I was going to bungy cord them up and over to the hood bracket to hold them up.
Will they drop right down if I've removed the oil feed lines and Y pipe?
I'll just take them off if they slip right down, I worry about screwing up the actuators and custom brackets I had made for the larger units.
My goal would be to remove the engine and tranny, as one unit leaving the turbo's in place if thats possible.
Thanks
The passenger side will practily drop out. The driver side you will have to take the actuator off and then it should come out. This shouldn't be that bad if you have a tubular k-member. Don't forget about the coolant lines.
Good luck. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Gary
