Decided on the ATI D1SC
Old Feb 10, 2003 | 03:38 PM
1BAD-SS's Avatar
Default Decided on the ATI D1SC
As the title says I've decided to go with the ATI D1SC Kit. I know that I need a set of 42lb injectors (need to know of a good brand), a fuel pump (need to know what kind). Now to run 8-10lbs of boost safely are there any other upgrades needed such as rods ect. I want to drive this not work on it all the time.
Old Feb 10, 2003 | 03:58 PM
Black LS1 T/A's Avatar
Moderator
Default Re: Decided on the ATI D1SC
SVO 42's would be good.
This Racetronix PnP solutioin seems great for your plans:
http://www.racetronix.com/rx-f1ls1-gss340m-fpk-a.html
or, you can go the inline Aeromotive Eliminator pump route.
Old Feb 10, 2003 | 04:57 PM
rodent's Avatar
Doesn't the Racetronix only work in 98 tanks? I think 99+ LS1's would have to upgrade to the steel tank right? According to 1BAD-SS's profile he has a 00.
I did a Walbro 340 in my plastic tank. Just had to splice the wires and put the old pump's shell around the Walbro.
<small>[ February 10, 2003, 04:59 PM: Message edited by: rodent ]</small>
Old Feb 10, 2003 | 05:50 PM
1BAD-SS's Avatar
Yes it is a 2000. This is why I asked this question, so I wouldn't end up buying parts that I didn't need or couldn't use.
Old Feb 10, 2003 | 10:09 PM
BIGBOS's Avatar
I'm running a 255L in the tank, and a 255 inline, ATI D-1SC 3.60" 8lb pully, I have ported heads and a blower cam (see sig)
Make sure they send you the right pully, they sent me a 4.00" pully which is a 5lb setup...with the 8psi pully, my car only saw 6psi...
