LS6 Heads/cam with blower
Old Feb 11, 2003 | 06:11 PM
Ping King's Avatar
Default LS6 Heads/cam with blower
Im pretty much set on the 7# ATI kit...i wanna keep the car 50 state..so i like the ls6 cam and should i do 6.0l heads or ls6 heads....its only 7#s so i should be safe...any inputs....and what kinda power are 7# ls6s pushing?
Old Feb 11, 2003 | 06:23 PM
rodent's Avatar
Default Re: LS6 Heads/cam with blower
Go with the 6.0 heads. Cheaper and larger chamber for FI. You can get them ported so they flow just as much. Figure 500+ rwhp
Old Feb 12, 2003 | 10:23 AM
35THSSLE's Avatar
See my sig...
Old Feb 16, 2003 | 11:08 AM
CHRIS NJ C5's Avatar
LS6 heads flow very well but are a little tight for a S/C car being about 64cc. Stock LS1 heads are a good choice if you are on a budget. If you can find a set of 6.0 heads go for it as they have the same flow rates as the LS6 heads at 72cc chambers. You will make 475 rwhp at about 7 lbs of boost. good luck..
