Project Dragula, Supercharger or Turbo
Old Feb 15, 2003 | 11:11 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: Project Dragula, Supercharger or Turbo
PSJ, I do realize that this is LS1 Tech, and that your goal here may well be to stick with an LS1.
BUT, if you are looking for some serious power out of a turbo setup, are you 100% certain that you want to stay with an LS1 based motor?
A small ci SBC motor with a stand-alone engine/fuel management system might be fun, or you could consider a Stage 2 buick setup. There are a few top notch S2 buick motors not attached to cars at the moment floating around Chitown (I know where a couple of them are but not sure if the guy will sell).
A nice S2 buick plant with twin 6Xmm or 7Xmm turbos and the proper trans should put you in the 1100+ hp range and in the 8s (low 8s possibily at the right weight) if you can get traction.
Just a thought. I know I've seen at least one 4th gen with a buick turbo 6 in it.
Old Feb 16, 2003 | 12:08 AM
Guido's Avatar
I dont like either option you have listed.
Why a single supercharger vs. two turbos?
Just put a 91mm Thumper on there and call it a day. Have a stout shortblock put together, put a FAST or DFI gen 7 on it, liquid intercooler and a good trans/converter combo and you'll have solid 8 second combination if you can keep it from lifting the heads.
Supercharger you are going to have the problems that Charlie mentioned. Its the reason I decided to switch from a supercharger to a turbocharger.
Good luck <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 16, 2003 | 01:36 AM
Shaitiger's Avatar
I'd suggest the new LS1 motorsports Single Turbo kit. The kit is throwing down some huge numbers.
Old Feb 16, 2003 | 05:43 AM
Black LS1 T/A's Avatar
Moderator
If a 422 is not too exotic for this project, it makes MAD torque BEFORE Forced Induction! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Make sure it has the light-weight forged internals and proper head/cam combo to let it rev at least to 7 grand, and let an ATI F2 take it to about 15 PSI of boost (you'd probably need the o-ringing job, studs to replace the head bolts and cometic gaskets to avoid lifting or warping the heads).
Of course, you will need the fuel system to feed it. That's MY problem, right now! <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" /> <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" />
Sounds like FUN! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> This should be interesting to watch! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 16, 2003 | 02:14 PM
Cmarsh93z's Avatar
Are you going to be using a stock computer setup? If so, go with a blower. The constant boost curve is alot easier to tune with once you get into the higher HP. If you want to be fast, with a quiet car...get a turbo and gen 7 <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Chris
Old Feb 17, 2003 | 12:21 AM
dug's Avatar
dug
What do you want out of your new set up? The fastest car on the board? Is money no object?
<small>[ February 16, 2003, 12:22 PM: Message edited by: dug ]</small>
Old Feb 17, 2003 | 08:25 AM
White_Hawk's Avatar
Go for one big gun like a T-88 or something on those lines. I have seen plenty of GN's in the nines on less turbo than that, if it's going to be a drag car, you can set it up with proper stall and a brake so that it beats the spool time advantage of the twins. If you are street racing, then that is probably another story...
-Geoff
Old Feb 17, 2003 | 09:34 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Ten more votes to 100.
Old Feb 17, 2003 | 09:42 AM
Raven's Avatar
I voted for the turbo <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
...It just sounds cool to say you own a TWIN TURBO Firebird <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Feb 17, 2003 | 11:05 AM
RyanJ's Avatar
SSU Moderator
I'd vote, but the choices suck. Why go with a YS and a water/air? Thats a little race-only for a dude like you. And if youre going that far...single turbo...you'll have the same amount of fitment issues <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> . Twins are cool, but we want to see something different....and faster than Tony this time PTE-88? Check BMR's car for the cool intercooler set up.
Old Feb 18, 2003 | 10:25 AM
LS1Tech Co-Founder
Thanks very much for your voting.
There are a number of awesome turbo setups coming out this year. I look forward to seeing Harl's car again this year, but also Rob Raymer's car and then some of the newer builds.
We have decided however, that there is a void.
There are no fast supercharged LS1 cars.
On that note, We are going to build stock cube 346ci LS1 with 6.0 heads and run a Vortech YS trim. We will be working with Vortech Engineering and several other companies to build what is hopefully a mid 9 second car. We plan to debut the car officially at the North vs South Shootout.
If the car does not run 9's at that shootout, and you voted turbo, please come up to me and I will buy you a beer. Or I will bring about ten cases of beer. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 18, 2003 | 11:35 AM
  #32
RyanJ's Avatar
SSU Moderator
you should do twin g-trims. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I wouldnt be that hard, right? two used head units and some custom mounts/brackets/pulleys.
Old Feb 18, 2003 | 01:10 PM
  #33
Guido's Avatar
Good luck John! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
See ya in the rearview. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Feb 18, 2003 | 01:17 PM
  #34
LS1Tech Co-Founder
Thanks Curt but we'll see about that.
Old Feb 18, 2003 | 01:59 PM
  #35
Guido's Avatar
The track down in Cincinnati opens in under 2 weeks here. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I'll be testing n tuning after that. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 18, 2003 | 02:02 PM
  #36
RyanJ's Avatar
SSU Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ryan:
<strong> you should do twin g-trims. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I wouldnt be that hard, right? two used head units and some custom mounts/brackets/pulleys. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">single blowers are for pu$$ies.
Old Feb 18, 2003 | 02:46 PM
  #37
Cmarsh93z's Avatar
Not everyone can be <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
glances over at 88mm of fury..
Old Feb 18, 2003 | 05:14 PM
  #38
The Juggernaut's Avatar
Mid 9's? I think BigBos was claiming he was
going to run that. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Best of luck,John.
Do yourself a favor-
DON'T skimp on parts.
Spend the money the FIRST time and do it right.
I think you already know this,though. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 18, 2003 | 05:37 PM
  #39
LS1Tech Co-Founder
I'm not looking to lock horns with BigBos, I don't mind being #2.
I'm ordering pistons and rods in the next two days.
Old Feb 18, 2003 | 10:27 PM
  #40
frcefed98's Avatar
Right on John,
Glad you are going with the blower. Look to be the same as far as progress on the build tho. I have the rods, new block and my set of 6.0 heads came in today(thanks Formulation) Pistons and rings are next and off to the machine shop she goes for assembly. I will be running 15psi or other combinations. I will be a fast S/Ced car (always have been) but the altitude I'm at makes me a .8-.9tenths of a sec slower than the rest of you bottom feeders.
So far money spent
Eagle rods $370
6.0 heads $450
Block $600
Talk about your budget HP, 600rw+ soon.
J <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
old PD times 12.1@117mph
new ATI 9psi will know on March 2nd
New ATI 348in combo?????
