ATI guys come in!
Old Feb 28, 2003 | 01:17 PM
1slowCamaro's Avatar
Default ATI guys come in!
Will a fluid damper crank pulley work with the supercharger crank pulley. Heres a link to one I found on ebay. Thought this might make up for some of the additional rotating mass we get when we add that ATI part to our stock crank pulley.
LS1 Fluid Damper
Old Feb 28, 2003 | 08:10 PM
1dirtyZ's Avatar
Default Re: ATI guys come in!
no i don't think it will work with the ATI pulley.
the ati pulley "sits" inside the crank pulley and uses the ribs on the crank pulley for support.
Old Feb 28, 2003 | 10:37 PM
1badvr4's Avatar
yes, that will work, however, you will need another 4 rib or 6 rib pulley(or whatever belt your sc uses) that mounts to the face of the dampner. that is exactly how my dampner is.
looking at the picture on the auction, the piece on the right runs the a/c and mounts up "behind" the piece on the left. in my case, the pulley for my sc mounts to the front of the dampner, the part on the left hand side.
Old Feb 28, 2003 | 11:12 PM
Are those quite a bit lighter than the stock crank pulley? The stocker is pretty heavy.
