What Cam for my setup
Old Mar 10, 2003 | 05:37 PM
ProTour69's Avatar
Default What Cam for my setup
I'm building a 68 Camaro with an LS1 T56 combo. The engine will be NA at first and then twin turbo. I only want to buy things once so I want to buy the right turbo cam now.
Heres My Setup:
MTI Stage 1 heads
Ported/powdercoadted Throttle Body
LS6 intake
underdrive pulleys
When I go twin turbo I will be using pistons and rods to lower the compression..I wll be running two T44 turbos at around 5psi of boost for the street and 10psi and race gas for the strip...what cam would you guys recommend I was thinking something along the lines of 227/224.534/530 @114lsa
Any help is greatly appreciated!!
Old Mar 11, 2003 | 02:30 AM
redz_02's Avatar
Default Re: What Cam for my setup
i would say try giving some of these guys a ring -->>, cam wise i am not to wise on cams for turbos, i do know that the duration looks nice for that whole exhaust velocity thing.
Old Mar 11, 2003 | 09:27 AM
smokinHawk's Avatar
maybe a 224/220-115
reverse split cam, desent NA. the duration might need to go up or down depending on your emisson/drivabilty requirements.
Old Mar 12, 2003 | 11:13 AM
ProTour69's Avatar
Thanks for the reply's guys I am going to give MTI and Cartek a call today!!
