6 liter questions
Old Mar 21, 2003 | 04:12 PM
bo0oost's Avatar
Default 6 liter questions
Hey there.
I'm going to build a motor for boost, and I had some questions.
I'm not going for insane horsepower, 600rwhp will be plenty. I think I can do this with 15 psi on a ATI D1SC. Will I have problems if i use the stock aluminum block with forged internals? Will I have issues with head lift? Anyway to prevent this? I might be able to make 600rwhp w/o running 15psi... maybe 12.
If so, I might just do the 6 liter block. Will my 5.7L crank fit in there? Can I move everything over? Oil pump, oil pan, etc? What will I need new to work with the 6.0?
How many cubic inch is the 6.0?
What will my compression be with 6.0 heads unmilled? 9.4?
Where can I get empty 6.0 heads, and an empty 6.0 block?
Thanks <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 21, 2003 | 04:34 PM
silent1's Avatar
Default Re: 6 liter questions
Yes, everything should swap over just fine. Depending on your pistons, the stock CR is, I think, 9.4:1. You can get a brand new block from SDPC for about $750 shipped. I have a brand new untouched 6.0 block and a set of used 6.0 heads I was going to use for a project that is taking the back seat for now. If you're interested let me know. I paid $1300 total for both, shipping included. I know I probably won't get it all back but, I don't want to lose much either.
aalvarez17@msn.com
Old Mar 21, 2003 | 05:46 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Those parts will easily sell in Chicago if you post them...
The 6.0 crank is the same as the 5.7... 3.622.
I think the motor works out to being like a 358? I forget.
Old Mar 21, 2003 | 05:59 PM
bo0oost's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>I think the motor works out to being like a 358? I forget. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Damn. So I'm officially going to have a big block!
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 22, 2003 | 11:30 AM
1dirtyZ's Avatar
big block??
i think the size is 366 cu.in. but not sure.
Old Mar 22, 2003 | 02:44 PM
bo0oost's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1dirtyZ:
<strong> big block??
i think the size is 366 cu.in. but not sure. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Oh. I thought big block was anything over 350ci.
Old Mar 22, 2003 | 02:53 PM
slow's Avatar
isn't a big block, a big block, not just displacement size.
Didn't GM make a 400 small block in the past.
Ryan.
Old Mar 22, 2003 | 03:04 PM
1dirtyZ's Avatar
yup slow is right , a big block referes to the physical outside dimentions of the block.
gm did make a 400 small block as well as a 400 big block ( if i remeber correctly).
now if you're going to get forged internals , why not spend the extra green and get a forged stroker crank just ot make things a bit more fun???
Old Mar 22, 2003 | 07:26 PM
jelibear's Avatar
The big-block 400 was just a 396 bored out a bit (402ci to be exact) in '70 or '71, was done to reduce emissions if I recall correctly.
Old Mar 22, 2003 | 09:47 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
I doubt you can run 15lbs with ati.I couldnt get a belt to last more than 4 passes with 8-rib and 10psi.Until someone develops a cog drive or something else for high boost setups your limited to about 10psi. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Mar 22, 2003 | 09:57 PM
bo0oost's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by t-76Y2KSS:
<strong> I doubt you can run 15lbs with ati.I couldnt get a belt to last more than 4 passes with 8-rib and 10psi.Until someone develops a cog drive or something else for high boost setups your limited to about 10psi. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What?
Is this true??
Old Mar 22, 2003 | 10:24 PM
10.5 Dave's Avatar
7 Second Club
I was just posting my personal experience with 6 liter h&c and D-1 8-rib setup.I went 10.91@126.85 at 3840lbs happy with power but belt breakage drove me nuts. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> Sold it,to frustrating for me.Good luck.
<small>[ March 22, 2003, 10:26 PM: Message edited by: t-76Y2KSS ]</small>
