Would my current fuel system be enough????
Old Mar 27, 2003 | 03:47 PM
BIGBOS's Avatar
Default Would my current fuel system be enough????
Right now I'm running a 255L inline pump and a 255intank pump, 42.5LB injectors....no problems w/fuel so far..
But if I upgrade to a 360+ iron block w/stock crank, upgraded internals, etc, would this fuel system be enough to support around 12psi?? That is what I'm shooting for if I do decide to do this, that would be the street setup...
Old Mar 28, 2003 | 01:20 AM
blown 346's Avatar
Default Re: Would my current fuel system be enough????
I dont see why it would be a problem, I think that you pretty much covered yourself with fuel so far.
Old Mar 29, 2003 | 01:50 PM
Black LS1 T/A's Avatar
Moderator
I agree that you are still where you need to be, as long as the inline is not creating a restriction that contributes to too large a fuel pressure drop. (That is, if you turn it on at boost. A pump controller that let's it run slower at cruise would solve that.)
