P1SC question
Old Mar 27, 2003 | 09:13 PM
2000silverbullet's Avatar
Default P1SC question
Is capping the tube from valve cover to charger a bad idea? What is this tubes job? Thanks.
Old Mar 28, 2003 | 08:59 PM
Default Re: P1SC question
Anybody? Pretty Please... <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" />
Old Mar 29, 2003 | 04:04 AM
00UNTAMED's Avatar
What might you be refering to?
You would always what to have a negatine pressure in your crank case. This would help your rings to seal against your cylinder walls. "MAKING MORE POWER"
Old Mar 30, 2003 | 09:03 AM
Well is there a way to stop the oil from sucking into the blower?
Old Mar 30, 2003 | 10:40 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
A one-way (pcv type) valve oriented so that only air can go in?
I believe that tube is called the fresh air inlet for the pcv system. In a stock setup metered air is pulled in there, goes through the crankcase, and exits the back tubes which come around to the pcv valve and then goes in the intake manifold. ATI moves that line to a pre-blower location so you aren't blowing boost through the engine. The downside is that doing this causes unmetered air to enter the intake via the pcv valve at vacuum conditions (i.e. part throttle), and most of the time ltrims rise and you have a general lean condition. Some people have moved the maf in front of that tube so the air gets metered. Some good results, some bad, it didn't work for me. Well it did 'work', but had other problems arise. Currently I have no pcv system. Experimenting with it and breathers.
<small>[ March 30, 2003, 10:47 AM: Message edited by: AzzHauler ]</small>
Old Mar 31, 2003 | 12:07 AM
Haven't people tried to make some sort of catch can that connects to the hose and creates a "catch" for oil. The reason why I'm asking is because I burning oil > about a 1.5 QT every 3000 miles.
Old Mar 31, 2003 | 07:24 AM
AzzHauler's Avatar
I don't know about specifically on procharger setups, but I believe smokinhawk is puttin one on his turbo. With the catch can you won't be changing how much is coming out of the motor, it just won't be inhaled. If you won't be pouring that oil back in the motor, then you'll still be 'using' 1.5 quarts in 3k.
