Safe to Supercharge with a 224 224 on a 112.
Old Mar 29, 2003 | 06:28 PM
JESSIE's Avatar
Default Safe to Supercharge with a 224 224 on a 112.
I'm wondering if I will be able to run a procharger on my current cam? I have a comp 224/224 on a 112 WITH 581/581. The car is a full bolt on cammed car with a complete BMR rear suspension and a Moser 12 bolt. It's also a M6 with a Ram VDS system with a 910 disk. I am planning on putting a set of 6.0 ported and polished with bigger valves but, do not plan on milling them any. I also was wondering if this is possible, which procharger kit should I get and how much boost should I run. Thanks Jessie
Old Mar 29, 2003 | 08:35 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Safe to Supercharge with a 224 224 on a 112.
You can SC your combo... With the lower LSA you will have great midrange but perhaps the topend will not be as strong as if you had a 114 LSA camshaft in there...
I'd look at the D1 and shoot for 6 or more lbs of boost...
