Turbo Cam specs ?
Old Apr 15, 2003 | 09:42 AM
Phil99vette's Avatar
7 Second Club
Default Turbo Cam specs ?
What cam would you use in a 347cid forged shortblock with 6.0l truck heads sporting 9.5:1 Cr?
Phillip
Old Apr 15, 2003 | 10:15 AM
smokinHawk's Avatar
Default Re: Turbo Cam specs ?
what are your drivablity requirements?
emission requirements?
what do you want to redline to?
could start witha 224/220-115 and adjust from there.
Old Apr 15, 2003 | 01:01 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Cam companies typically recommend more intake duration for turbocharged applications, and the opposite for supercharged setups.
I think one way to go at this, is to find verify where Harlan peaked, and then go from there... I think he picked at 6400 with his setup... 228/224//112... I'd verify that because I could see a setup like that peaking sooner. Also I would look at whether bigger turbos or other differences in setup will affect the peak. Maybe look at some NA dynos too. My blower should move my power peak up 500 rpms higher than where it would be NA. NA my motor would I think peak around 6400.
Old Apr 16, 2003 | 12:10 AM
LS1Tech Co-Founder
How high you want to buzz the motor?
Old Apr 16, 2003 | 12:28 AM
7 Second Club
The heads have a I/E efficiency of 73% and shifting at 6000-6800. The motor has forged internals.
Phillip
Old Apr 16, 2003 | 12:46 AM
LS1Tech Co-Founder
So if you shift at 6800 you want it to peak lower than that so say 6500?
I'd say no more than 237/230//115/+2, that might peak too high for you.... Maybe 230/224//115/+2.
My blower cam is 230/237//115/+2 from FMS and we will shift it around 7000-7200.
Old Apr 16, 2003 | 12:53 AM
7 Second Club
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong> So if you shift at 6800 you want it to peak lower than that so say 6500?
My blower cam is 230/237//115/+2 from FMS and we will shift it around 7000-7200. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Would you run more duration on the intake or exhaust? I figured the exhaust since there is such a restriction in the exhaust with the turbine housing. Thanks for the quick replies.
Phillip
