PT or the like turbo lifespan?
Old Nov 10, 2005 | 11:23 AM
Scalpel's Avatar
Default PT or the like turbo lifespan?
What's the typical lifespan of the ballbearing PT turbos, or the like?
Old Nov 10, 2005 | 11:34 AM
NOSjohn's Avatar
Restricted User
Most Garret Turbos offered on factory cars (non-b.b.) last the life of the car. This is usually 100,000 miles plus. In certain cases I've seen turbos on the Buick turbo cars where they need replacing at 50k, 70k, etc. The replacement is usually a circumstance of how well the car was NOT taken care of and upkeep. If properly maintained a ball bearing turbo should last a long time. This includes oil changes, air filter, making sure your feed line and drain line aren't clogged and intermittantly checking play of the turbo (side to side and up/down).
