Procharger...What else is needed?
Old Nov 16, 2005 | 02:10 PM
SUPER DAVES Z's Avatar
If you have the tools, you could probably install it in a weekend. That would save you a bunch of money. I don't know of any tuners in the Austin area, but I'm sure there are some good ones in and around Dallas. Mike Murillo in SA does a decent job tuning FI cars.
FWIW, if you do want to try and install it yourself, shoot me a pm. I could maybe help you out. I even have an extra 99 pcm (with a turbo program, 42lb injectors ect.) you could barrow until you were able to get yours tuned.
Later,
Dave
Old Nov 17, 2005 | 04:07 AM
HILL_SS's Avatar
Alright I will get the gauges too...Am I missing anything else so far that someone hasnt mentioned....
Also which is the best brand for the 42 lb. Injectors?
And as for the Y-Pipe Diameter any one have suggestions on my previous questions...will my 2.5" work...it goes into a 3" at the I-Pipe on...Anyways Im almost squared away...I think...the list gets a lil longer with each post
Old Nov 17, 2005 | 11:42 PM
HILL_SS's Avatar
Any other suggestions?
Old Nov 18, 2005 | 08:18 AM
WAHUSKER's Avatar
Are you going to stick it on your existing motor? As in no cam/heads/piston work? If so then you might be able to use your 6 rib pulley setup. Once you go higher in boost / hp, then an 8 rib is required to prevent belt slipping. The s/c I bought came with the larger MMS crank pulley & 3 blower pulleys that the guy was making about 8 psi with & had minimal slippage (& it made 471 rwhp on a stock motor).
But I am going to run the Pro Street class with my car so I had to change over to an ATI Damper (SFI rated) which means 8 rib. (which means I now have 5 pulleys I can't use ) I'm also going to change it into a D-1SC @ ~ 12 psi so I need the Ractronix pump & 60lb injectors &.....
The point I'm trying to make is, what you need to do depends on what you plan to do with the car.
