proflow bypass valve on procharger dsc1
Old Nov 21, 2005 | 06:40 PM
boosted99camaro's Avatar
Default proflow bypass valve on procharger dsc1
just installed my procharger on my 99 z28 and was vary easy but just one question.I have the proflow bypass valve,can you install it in eather direction or is there a certin way it goes.also when you close the butterfly you can still blow thruough it a little is that normal?
Old Nov 21, 2005 | 07:49 PM
618HAWK's Avatar
AS per the install manual they state that the inlet end is the end with the screw head in th butterfly valve
Old Nov 21, 2005 | 08:00 PM
Brent@LPE's Avatar
yes the blow-by is normal on the valve,it doesnt seal as tight as you might think
Old Nov 21, 2005 | 09:34 PM
thanks guys.
