Do I need a vacum pump?
Old Dec 4, 2005 | 06:16 PM
2toneblown's Avatar
Default Do I need a vacum pump?
So when i was at 12#s of boost I had no problems but now that I am at 25#s I have an oil leak after getting into that much boost. I pulled the intake off and found out that where the knock sensors use to be there is a puddle of oil. So i am guessing there is too much pressure in the crank case so do i need a vacum pump or what????
Old Dec 5, 2005 | 02:38 AM
smokinHawk's Avatar
usually just venting it solves most problems.
Old Dec 5, 2005 | 03:40 AM
EPP's Avatar
EPP
At that much boost a vacuum pump would certainly help you out. Bob
