jethot 2000 for turbo manifolds?
Old Dec 5, 2005 | 09:36 PM
30th t/a's Avatar
Default jethot 2000 for turbo manifolds?
is it worth getting my 321 stainless steel manifolds jethot coated to help from cracking? i just want to know if its worth it or are they going to crack anyway? alot of the guys on turbomustang.com like the jethot 2000.
Old Dec 5, 2005 | 09:46 PM
METAL MAN's Avatar
Will not help with cracking really, it's more to help with keeping the heat in the tubes and less heat outside the tubes. 321 is very very heat resistant to cracking long as the turbo is properly supported. The Jet Hot 2000 is fine or the HTP 1600 works great also.
Old Dec 6, 2005 | 05:29 AM
smokinHawk's Avatar
if they do crack with the coating on there, its a pain cause you have to take off the coating before you weld it back up.
