Problem with autometer A Pillar
Old Dec 7, 2005 | 05:45 AM
cputech's Avatar
Default Problem with autometer A Pillar
I'm running a boost and fuel pressure gauge. Not sure if anyone else has ran into a fit issue but I cannot get the lower side of the darn thing to sit flush against the side *see picture*.
The top portion and sides fit perfect, its just the bottom.
Old Dec 7, 2005 | 06:16 AM
Spade's Avatar
My Pod Gauge went over the A-piller. I screwed my pod gauge into my piller so that it would fit nice and snug. Other than glueing it I dont see any other way around unless you just have not pushed it all the way down?
Old Dec 7, 2005 | 06:30 AM
King James's Avatar
It looks like you have the gauge pod pushed down too far. Have you tried placing the pod higher up on the a-pillar?
Old Dec 7, 2005 | 07:31 AM
White.Lightning's Avatar
If that is a dual pod (not the full pillar), it is definitely too low. The dual pod should be rougly 1/3 of the way from the bottom, with the highest point being around 1/2 way. If it is a full pillar, I do not know what to tell you other than try to readjust it.
Good luck
Andy
Old Dec 7, 2005 | 08:36 AM
cputech's Avatar
Thank you gents.. I will try and pull it and see what adjustments I can make.
