first tuning session of new setup
Old Dec 13, 2005 | 11:47 AM
  #41
V8_DSM_V8again's Avatar
By reducing cylinder pressure by increasing overlap, is that what you mean?
You can also limit cylinder pressure by leaving overlap as is and increasing intake duration..
Its obviously dependant on RPM but a intake valve that closes later than optimum for a given rpm will push air back thru the intake port..
Honestly my favorite method to lower cylinder pressure is to simply drop the static compression ratio...
Old Dec 13, 2005 | 12:24 PM
  #42
ddnspider's Avatar
Originally Posted by V8_DSM_V8again
Well the lSA on that cam helps to make up for less duration and I have been runing that cam on the computer with AFR 225's..
You dont need alot of intake duration with those heads and FI.. There is also the issue of when the valves open and close in relation to the pistons timing as opposed to just total duration.
Its a split with a little more duration on the exhaust side still a smaller cam. I think the exhaust side is just right too.. Not opening to early as to loose some of a turbo engines more degrees of power on the power stroke and hits a pretty good sweet spot on the exhaust valve close point too.
I'm looking for a 6000 rpm hp peak... Actually I concentrated on huge low and mid tq and ended up with a 6000 rpm hp peak...
Just curious what program youve been using?That cam could benefit from more lift in addition to what you said....with a lift of .515/.522 it leaves a bit more room on the table especially at higher rpms.If hes planning to shift at 6800 then he'd want a lift somewhere in the .58X/.59X range. Its true that you dont want the valve lifted much past the peak flow but the air coming in is pressurized.So say the heads flow best at .500 lift then to get the full potential he's want a cam lift of about .600 or a bit more.If you lift the valve only to its peak flow point, then the valve only flows the best when it's wide open.And we know AFR heads are going to flow well straight out of the box so....
Old Dec 13, 2005 | 12:35 PM
  #43
http://www.performancetrends.com/Eng...r_Pro_v3.3.htm
Run higher ratio rockers like 1.8 crane quicklift rockers if you want some more lift...
I doubt he will need it.. AFR has their flowbench data up...
Alot also depends on the shape of the cam lobe.. An agressive profile will hold the valve open higher...
Old Dec 13, 2005 | 05:50 PM
  #44
BizZzatch350's Avatar
Moderator
Awwesome numbers, that car is a beast.
Old Dec 14, 2005 | 09:36 AM
  #45
CP05GMC's Avatar
Come on Tiago, get yourself a nice little X-mas present and order up the heads/cam/snow kit.
Cp
Old Dec 14, 2005 | 09:59 AM
  #46
ESR's Avatar
ESR
LS1TECH Sponsor
Default .............
Id be happy with just the snow kit for that car so I could give it more timing and boost.
Cp
Old Dec 14, 2005 | 12:18 PM
  #47
Tiago's Avatar
Cp
DAMN HOA anual fee's
we'll do something
need to get those vids up
