Guestimated RWHP??? Hello all: My car is almost ready. All they have to do is work out the tune. I currently have the TTi race kit (Turbonetics T76GTQ trim), built 370ci iron block with 8.5:1 compression, 60# motrons, factory ECU w/LS1Edit tuning, which is working out very well, and a TH400 w/3000 stall converter. I plan on running about 15PSI on pump and about 20+PSI on race gas. Just wanted a guestimation from everyone. On a good tune, what do you think she'll do? This will be on a Mustang dyno. |
I think she's going to push somewhere around mid 7xxhp @ 15psi and probably north of 900rwhp @ 20psi...Good luck and keep us posted |
Originally Posted by 98turbls1 I think she's going to push somewhere around mid 7xxhp @ 15psi and probably north of 900rwhp @ 20psi...Good luck and keep us posted What kind of heads/cam? I am gonna guess 580-600rwhp @ 15psi and 700rwhp-720rwhp @20psi all on a mustang dyno... |
Whoooo Quick I think you are way undershooting it... I make 560 with an STS and a 67 Trim turbo at 9Psi. I think 98 is pretty close... I dont know what it will do at 20PSI however... 850 maybe |
625rwhp 15 psi (Mustang Eddy current dyno), and 750rwhp 20 psi. Really I have no idea and just wanted to post. :) |
I estimate you will need bigger injectors for 20psi ;) |
Originally Posted by longrange4u Whoooo Quick I think you are way undershooting it... I make 560 with an STS and a 67 Trim turbo at 9Psi. I think 98 is pretty close... I dont know what it will do at 20PSI however... 850 maybe |
Originally Posted by kp I estimate you will need bigger injectors for 20psi ;) |
Originally Posted by RealQuick Thats seems kind of high to me (especially the 20psi guess) because he has an auto/stall and its on a mustang dyno. JMO though. What kind of heads/cam? I am gonna guess 580-600rwhp @ 15psi and 700rwhp-720rwhp @20psi all on a mustang dyno... KCR stage 2 heads Thunder Racing 224/224 .561 .561 cam |
Originally Posted by Mekkadon I thought so too, maybe some RC 75# injectors? |
A T76 with a Q-trim at 20+psi is going to be tough to make good power (if any more then 20 without side effects) without backpressure becoming a big issue. Also the IAT's will be screaming...make sure to pack plenty of ice in the IC. ~95 lbs/min, 2.36 PR, you will be way off the compressor map....~55% efficiency. Your compressor outlet temps will be floating ~410-420DegF. Just something you may want to think about. Jose |
Originally Posted by JZ 97 SS 1500 A T76 with a Q-trim at 20+psi is going to be tough to make good power (if any more then 20 without side effects) without backpressure becoming a big issue. Also the IAT's will be screaming...make sure to pack plenty of ice in the IC. ~95 lbs/min, 2.36 PR, you will be way off the compressor map....~55% efficiency. Your compressor outlet temps will be floating ~410-420DegF. Just something you may want to think about. Jose So, what PSI nets the best efficiency for my setup? I noticed in INTMID8's post on a similar setup here (TTi race kit hot parts) he was able to make around 900RWHP (though it was an M6) but he is running a bigger A/R on the Innovative Turbo than my Turbonetics (1.15 vs my .96). Or, are there more differences between the Innovative and the Turbonetics as far as efficiency/power is concerned? I don't know if it is possible to switch to the T76GTS with this TTi race kit. Would that help any? Guess I'll have to make a couple of phone calls. (or if mightymouse or anyone else have input, please chime in). |
Congrats Eddy, man I finally get to see the beast :drive: |
700RWHP @15psi. And if you don't run out of injector at 20 psi around 900rwhp... Thats my guess. |
Originally Posted by Mekkadon So, what PSI nets the best efficiency for my setup? I noticed in INTMID8's post on a similar setup here (TTi race kit hot parts) he was able to make around 900RWHP (though it was an M6) but he is running a bigger A/R on the Innovative Turbo than my Turbonetics (1.15 vs my .96). Or, are there more differences between the Innovative and the Turbonetics as far as efficiency/power is concerned? I don't know if it is possible to switch to the T76GTS with this TTi race kit. Would that help any? Guess I'll have to make a couple of phone calls. (or if mightymouse or anyone else have input, please chime in). Jose |
The 60's better be boost referenced with a regulator. Saw one graph with them at +800rwhp, another at +1000rwhp....both boost referenced. |
so whats the order on the T76.....Q...R..S? |
P, Q, R , S, X , S4. Jose |
Originally Posted by JZ 97 SS 1500 P, Q, R , S, X , S4. Jose O P Q X,S (same wheel different name?) R Don't know about the S4. |
In order it would be... O, P, Q, X, S, R , S4 and TM1....forgot about the last. The TM1 is new and is very hard to get right now. BTW, the X is a touch smaller then the S. Its an R-trim wheel with a step cut into it. Jose |
© 2024 MH Sub I, LLC dba Internet Brands
