LS6 intake manifold restriction?
So, it seems on our car at that level the intake was worth about 1mph.
the ls6 does flow pretty well,
the fast has had problems at high psi.
ls6 outperforms sheetmetal and single runner down low, but when you get up in the 6000rpm range the sheetmetal and single plane take over
To try to answer your question, the fact that you are pushing air through the intake via boost, you will likely never find a point that it stops flowing enough to make more power with added boost. You will eventually find a point where it will become worth while to upgrade, but I bet it wont be until you reach way beyond anything anyone is willing to try. One thing you will eventually find is the forward facing TB style intake will start to lean out the back cylinders at higher boost levels, I would imagine this is why the Ohio boys are using the diffrent intake.
-Bryan
i noticed alot more are was getting to either then back or front (cant remember which)
didnt seem equal.
trying to remember but i think i made my 512rwhp on the mustang dyno with the ls1, i didnt get it redynoed after that. so i dont know what all gains i made.
