First runs on the 408 /T88 combo
Here is a nice oil inlet with a restrictor hole....check it out:
http://cgi.ebay.com/ebaymotors/F7-T3...23081166QQrdZ1
Here is the consumption chart for a 408. It is a conservative map though I built using a lower VE and 120 degree intake temps. IF you need an accurate map let me know....I should be able to show what you will map before you even roll it onto the dyno again...hehe.
408 consumption
JZ
- Dug
