Max boost on a stock 5.3...
Old Dec 24, 2005 | 07:52 PM
Sledgehammer's Avatar
Default Max boost on a stock 5.3...
I have a buddy that has been buggin me to put a turbo on his 5.3...
It will be a stock 5.3 with bigger injectors using the stock truck exh. manifolds turned around and either two small turbos or maybe a Master T-70 running through a intercooler...
So what do you all think...? How much boost can I pump into this beast before the pistons and /or rods exit stage left...?
Also what size injectors do you think would be good...?
Fire away...
Old Dec 24, 2005 | 09:47 PM
red90cobra's Avatar
I would suggest putting stock 6.0 heads on it. it would bring the compression down a bit. 60lb injectors so you have room to make power without changing them again for a while
