Injector size for turbo?
Old Dec 31, 2005 | 07:26 PM
80superbu's Avatar
Default Injector size for turbo?
Looking for some guidance for picking injectors. Right now I have a 2001 LS1 motor that I am adding a turbo to. All internal are stock except cam, which is a turbo cam. I can't remember off hand what turbo I have lined up (it's on my work computer ) belive it's a 60 series or so. Was planning to run 5-7lbs of boost.
Opinions??
Thanks
Old Dec 31, 2005 | 07:30 PM
93formto98T/A's Avatar
Running stock internals will set you at a maximum reliable 500-550rwhp with a good tune. In that power range you would be best suited with some 42lb injectors. IMO a T76 is a bit overkill for the power you are after. You would get a much quicker spool with a smaller turbo i.e. T61 or T67.
Old Dec 31, 2005 | 07:48 PM
80superbu's Avatar
I edited my post about the turbo size but I guess it was after you posted. I did go with a smaller turbo and 500-550 is about all I really wanted...for now
Old Dec 31, 2005 | 08:23 PM
ddnspider's Avatar
you can do the stock injectors til 450-475rwhp then the duty cycle of them is too high....if you plan on making alot more later skip over the 42#ers and get the 60#ers so u have room to grow and dont have to buy twice.
Old Dec 31, 2005 | 08:28 PM
80superbu's Avatar
OK, found the turbo. It'a a Master Power GT45. I talked with Jose at Forced Inductions a few times and that is the one we came up with.
So I will at least go with the 42's. Before I outgrow that turbo I would have to get a new rear axle and transmission. Not quite ready to do that
