guys w/ alternator relocation.....
Old Jan 2, 2006 | 09:41 PM
SELLSZ06's Avatar
Default guys w/ alternator relocation.....
How can I run a breather on on the oil fill whole? The way mine is with the stock alternator and stainless works relocations bracket theres not even enough room to screw in the stock oil elbow or the cap. Right now I have a stock oil cap that I grinded the edges, but I need to run a breather to relieve some pressure. Anyone one have pics???
Old Jan 2, 2006 | 10:49 PM
disassembled's Avatar
You don't need to run a breather if you set up a good PCV setup (like what MM is using). He runs all of his PCV connections to the air inlet after the filter to create a constant vacuum under boost. Eventually i will convert to his setup down the line but i don't have enough time to worry about it now.
I am sure you could swap to a different valvecover if you really wanted a breather setup.
Greg
Old Jan 2, 2006 | 11:07 PM
frcefed98's Avatar
Look closely and you'll see the "mod" I had to do to my mesh breather on the valve cover. Still works, not too pretty but its functional which matters most. Just had to smush the breather a lil.
J
Old Jan 3, 2006 | 05:25 AM
smokinHawk's Avatar
get a better alternator bracket (one like mine) and fit a breather on it with no problem
Old Jan 3, 2006 | 10:31 PM
SELLSZ06's Avatar
thanks forcefed, Ill try that w/ the bracket for now til my Hi-Flo manifold comes in, then Ill put the it on the elbow.
Old Jan 4, 2006 | 02:57 PM
frcefed98's Avatar
No problem, sometimes you just gotta work with what you have.
J
