317/ 6.0 head question
Old Jan 9, 2006 | 02:19 PM
Yellowsierra's Avatar
Default 317/ 6.0 head question
How much boost should a stock 317/Lq9 head be able to hold with Arp bolts and cometic headgaskets? I know the gm castings have a thinner deck (.375") compared to some of the aftermarket heads, AFR, Allpros, edelbrock ect. I want to be able to run atleast 15 psi and dont want to change the headgaskets everyday. So should the stock 317s hold up?
Old Jan 9, 2006 | 02:29 PM
HydroStream6's Avatar
From the research I've done, they should hold up. From what I've read, to avoid the heads from lifting at all, you will probably want to use ARP studs rather than bolts. As far as the head gasket, I'm using a MLS gasket with 241 heads and haven't had problems at 9psi, and I plan to run 14 on them this spring.
Old Jan 9, 2006 | 02:48 PM
Yeah Ive got studs my bad. I was thinking about buying the older 6.0 cast iron heads. They should hold the boost.
Old Jan 9, 2006 | 04:15 PM
nitrorocket's Avatar
Aluminum 317 heads with stock mls gaskets have held close to 30 lbs of boost! I am at 15 psi on pump, no problems.
Old Jan 9, 2006 | 04:35 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
17-21psi in my car with GM MLS headgaskets.
Old Jan 9, 2006 | 04:44 PM
Mike 01WS6's Avatar
The old cast iron 6.0 heads are junk. You couldn't give them away if you tried.
