what to use for Twins....
Old Jan 13, 2006 | 06:10 PM
HellRaiser's Avatar
Default what to use for Twins....
Just wondering what turbos you guys think I should use for twin setup? My plan is to make 600+ on pump and then run race gas and really hit the sweet spot for the turbo's. What would you guys use???
Old Jan 13, 2006 | 06:54 PM
30th t/a's Avatar
t3/t4 twin 57mm.
Old Jan 13, 2006 | 07:01 PM
HellRaiser's Avatar
I was thinking something in a 60 trim... maybe to big or great for race gas?
Old Jan 13, 2006 | 07:11 PM
30th t/a's Avatar
i think t60's would be to big for 600rwhp. i like the twin 57mm's HP uses in their kits. check out some of the cars. their making 800+ on the twim 57's.
http://www.google.com/url?sa=X&revid...rgedpower.com/
Old Jan 13, 2006 | 07:16 PM
30th t/a's Avatar
i got a vette mag. and they dyno a 02 zo6 stock and it makes 356/331 and then they install a HP twin 57mm turbos, a tad over 7 psi and they make 551/529. at 3200rpm the vette was making 400ft/lb rwtq. i think thats great for the street.
Old Jan 13, 2006 | 07:20 PM
Slowhawk's Avatar
LS1Tech Sponsor
For 600hp they would be pretty small. We've run twin 60's to almost 1000hp and they can probly go higher.
Old Jan 13, 2006 | 07:23 PM
HellRaiser's Avatar
Thats what I am thinking. I can go a LITTLE big for street but once the boost is turned up I like to make power!!!! So you think a 60 trim is the trick?
Old Jan 13, 2006 | 07:52 PM
eviltwins's Avatar
When people like HP say twin 57mm turbos what they actually mean are T3/TO4E 57-trim turbochargers, which just happen to have a roughly 56mm inducer. T3/TO4E 57-trim's and T3/TO4E 60-trim's will support basically the same amount of power, with the right turbine wheels they will make roughly 450-500 RWHP each.
 Michael S. Palmer
Old Jan 13, 2006 | 08:01 PM
HellRaiser's Avatar
So your saying that the 57 and 60 trim could make the same power just depends on the turbine wheel combo they use?
Old Jan 13, 2006 | 10:20 PM
93formto98T/A's Avatar
Check out the GMR TT kit if you haven't already. They are running 2 T61S turbos rated at 700 a piece.
Old Jan 13, 2006 | 10:21 PM
eviltwins's Avatar
Yes, the 57-trim and 60-trim TO4E wheels are very similar in size and flow within a few pounds of air of each other. So you're talking a 30-40 horsepower difference on a set of twins.
Pretty much any mid sized set of twins will do 600 RWHP on pump gas on an LS1 without breaking a sweat, but you gotta set a real top end goal to know what you need.
