Different Spring rates intake and exhaust
leaving 63.3 lbs seat pressure. about half of what is desired. Now the exhaust is different, most of us are probably running between a 2:1 and 3:1 pressure ratios. At 2:1 that would be 14 psi times 1.88 = 26 pound trying to open the exhaust valve, and at 3:1 its 21 psi times 1.88 = 40 lbs. So I'm looking at the Comp Cams springs 26915-16 @ 105 lbs and 26918-16 @ 130 lbs. I was thinking of running the 105's on the intake and the 130's on the exhuast, what do you guys think? Or just stick with one or the other?
