A good way to a safe 650 HP with STS
I already have the STS kit with the standard turbo with a custom dyno tune. I also have 42lb injectors.
My next step is to install an FMIC, meth/water kit, and higher flow fuel pump. I will also up the boost to at least 8psi and get another custom tune to accomodate the changes.
I will upgrade the valve springs and rockers soon after.
My next step will include stronger bottom end, probably a stroker short block with a 8.5:1 compression.
What small details am I missing? Is there something I should upgrade with one of the steps to keep my engine from blowing or just for preventive maintenance? Is there a better way to my HP goals. The car is a weekend driver so I'm not that concerned with gas mileage, but I do enjoy taking it on 3-4 hr highway road trips at excessive speeds and do not enjoy having to stop for gas excessively.
But either way, on a stock bottom end, 650rwhp
What was your mods on the 11.29 run? Man I love the sound of the STS.
As for the thread starter... you want 650RWHP with your STS without having to rely on Meth? Harden your lower half... I am at 600 and at the limits of the stock piston rings I belive. If you do what your talking about but in a different order:
1st- Harden your block (Hell even look at the option of going to a larger cube like 370 or 402)
2nd- Upgrade your fuel setup to include 60lb injectors (dont forget lines and pump)
3rd- FMIC
4th- 70 trim turbo
5th- An outstanding tune (Speed density is a good consideration)
This will equal at 10-12 PSI 650RWHP easy without the fear running out of meth and *boom*. I belive that this setup is infact good for 700+RWHP.
I ran an 11.6 at 114 with a 60 trim turbo at 8.5lbs
I ran an 11.29 at 124 with a 67 trim at ~7lbs
I will run a 10.something with my 67 and setup in sig at 10-11lbs of boost (Per reccomendation of friends on here I will ritchen up my tune some first)
All of this was done at FULL weight... 3845lbs. I have not even pulled my spare tire. John (PSJ) is witness to it.
in that order.
everything else is reliability and support mods allowing more boost safely.
heads, cam, efficient and well size matched fmic, proper piping all help, but that's small potatoes comparing to giving it another 5psi on a big flowing turbo.
It should be in the 10's on the low boost setting. Bob
