Blown 383 LT1 cost comparison
Old Jan 18, 2006 | 01:46 AM
Blown383's Avatar
Default Blown 383 LT1 cost comparison
Does this look right in terms of costs for a blown 383? I'm trying to find out if the price is reasonable.
Block machining w/hone deck $300.00
Valve job $110.00
Pressure test heads $ 0.00
Cylinder head resurfacing $ 70.00
SCAT/JE Rotating assembly + $1389.00
cam, bearings, ARP main studs
Upgrade to 4340 steel crank $250.00
Upgrade to 4340 H beams $120.00
Assemble long block $450.00
Complete balance $125.00
Stroker clearance $ 45.00
Canton 15-242T Pan $283.00
Oil pan pick up $ 34.00
Cut dual key crankshaft $100.00
Gasket set $121.00
ARP head studs $171.00
Melling oil pump $ 0.00
Machine timming cover for BB hub $ 20.00
Total labor: $1200.00
Total parts: $2368.00
Total + 8.25% sales tax $3763.36
-B
Old Jan 18, 2006 | 06:20 AM
engineermike's Avatar
I don't see anything about a 4-bolt main conversion. I consider this very important since, even with my 4 bolt billet caps, there is fretting on the block where the caps are moving around. That's at about 850 fwhp.
Mike
Old Jan 18, 2006 | 06:22 AM
JasonShort's Avatar
Moderator
Blown383, I saw the pics of your project in the LT1 section....looks good!
Are those the prices you were quoted? If so, they seem to be reasonable. I would have guessed that the machine work would have cost more than that. I own a 383 and have worked in a performance engine building shop and the prices (machining) at this particular shop were near double of what you have posted.
Jason
Old Jan 30, 2006 | 09:27 PM
Blown383's Avatar
Glad to hear that the costs are reasonable because I am going broke. How much does the 4 bolt main conversion typically cost? Because from the research that I have done 4 bolt splayed conversions are overkill, most folks that I talked too said they did it just because the motor was already apart and that they just went ahead with it. I don't plan on making more than 600hp because that would require a F1 to replace the D1.
-B
Old Jan 31, 2006 | 12:38 AM
DeltaT's Avatar
For a blown 600HP, you can stay 2-bolt and save some money. You won't have to rev it high enough to worry. I would go to ARP main studs, like you mention though. Work hard not to detonate.
I would also spring for file-fit moly Speed-Pro rings and one of the hand crank ring grinders. Time consuming but a good source of power if you do it right.
Jim
