boost and power on stock motor?
Old Jan 19, 2006 | 03:35 PM
shanekretz's Avatar
Default boost and power on stock motor?
How much boost and how much power is reasonably safe to run on a stock ls1?
Old Jan 19, 2006 | 03:52 PM
Steel Chicken's Avatar
varies. 6-8lbs, 500-550rwhp
some people get lucky and run 10lbs+/600rwhp with no problems. some dont.
detonation is what usually kills the motors.
if you can drop the compression ratio a full point and run meth, that will significantly reduce your chances of extreme motor ouchieness.
Old Jan 19, 2006 | 05:15 PM
nitrorocket's Avatar
Search!
Old Jan 19, 2006 | 05:43 PM
mdhmi's Avatar
I've been running 9-11 lbs for two years on a stock bottom-end. Anywhere from 500-600 rwhp.
Mark
Old Jan 19, 2006 | 05:45 PM
Zombie's Avatar
I wish someone would ask this question every week!
Old Jan 19, 2006 | 07:42 PM
EPP's Avatar
EPP
An ATI ProCharger at 8 psi on an LS1 engine that has headers and an exhaust, will generally add 140 rwhp extra on top of the same combination minus the supercharger. 8 psi will put it at 440 to 450 rwhp on my Mustang Chassis Dyno. This is a very safe set-up provided you have a have a good tune. You can get away with an extra 50 rwhp, but I see 500 rwhp as the overall safe limit for the customer to have a good dependable engine. I have one customer whose engine and it's stock bottom end has been at 575 rwhp for several years. I have no idea why it's still together, and he doesn't either... Bob
Old Jan 19, 2006 | 08:01 PM
longrange4u's Avatar
