procharger question
Old Jan 21, 2006 | 06:25 PM
d-1sc408's Avatar
Default procharger question
I recenly bought a D1SC procharger, I have also 500Hp Heads and Cam package from SLP and I have a Moser 12bolt rear end with 410 gears. Any ideas of Dyno numbers with 10psi and the stock bottom end
Old Jan 21, 2006 | 07:04 PM
onefastss223's Avatar
560rwhp/490rwtq...just a guess...I made 620rwhp with 10#'s through a P1SC with 6.0L heads, a blower cam, and a alky control kit...I hope this helps you out a little
Old Jan 21, 2006 | 07:14 PM
Got Me SOM's Avatar
depends on what compression and cam you have. High compression will limit how much boost and timing you can run.
Old Jan 22, 2006 | 07:44 AM
EPP's Avatar
EPP
I'd say over 550 rwhp on a Mustang Chassis Dyno. It is going to need to be tuned on the rich side, I'd shoot for 11.2/1. That 408 that is coming may be needed sooner than later... Bob
