Stroked N Blown Project
Old Jan 21, 2006 | 06:48 PM
Texas Heat's Avatar
Default Stroked N Blown Project
I am trying to figure out what the best combo is. I am looking to do a iron block 427 boosted, any suggestions?
Old Jan 21, 2006 | 06:58 PM
Got Me SOM's Avatar
proven combo is a 408 (iron) with whatever power adder you want.
if you want your front end to be lighter go with a aluminum 402.
can't go wrong either way.
how fast ya looking to be?
Old Jan 21, 2006 | 07:03 PM
Texas Heat's Avatar
Im not real worried about a track car, I want something I can have fun with on the street.(highway)
Old Jan 21, 2006 | 07:10 PM
Got Me SOM's Avatar
408 for the win.
pontiac's Avatar
looking at doing a 408-402 with a highflow street killer set up. or at least that was the plane wanting over 800rwhp on pump gas??????????? is this posable
Old Jan 21, 2006 | 07:11 PM
Got Me SOM's Avatar
there are people making power in the mid 700's with pump gas.
Old Jan 21, 2006 | 07:27 PM
Texas Heat's Avatar
im not looking for 800, I just want a motor I can be confident with against most everything I will run into on the street scene.
Old Jan 21, 2006 | 07:28 PM
Texas Heat's Avatar
i guess I am going to go with a Blown 408, sounds like the winner.
 Michael S. Palmer
Old Jan 21, 2006 | 08:46 PM
2001WS6Vert's Avatar
I'd recommend an aluminum LS2 402. No need for the extra weight of the iron. W2W is selling 1250fwhp aluminum LS2's, they can take the power.
Old Jan 22, 2006 | 07:58 AM
NA$TY-TA's Avatar
I dont like the blown idea either...... im not a fan o SC anymore..... been there done that,,,,,, sold that.... Go Turbo....
Old Jan 22, 2006 | 11:32 PM
pontiac's Avatar
so what is the big difference with going with IRON i know stronger but how much??? and i know its alot more weight. but where is the line when you decide to buy a IRON block, over a aluminum. if i buy a aluminum one are my hp goals out of reach?? how much bost can it take????
Old Jan 23, 2006 | 12:20 AM
ChaseSS's Avatar
there was C5R 427 built for forced induction in the for sale section and i garruntee you with that engine in combination with any blower/turbo setup would be bullitproof
Old Jan 24, 2006 | 05:34 AM
1dirtyZ's Avatar
don't listen to nasty! its the fues that are talking not him
get an iron block for durability : for instance, if you ever blow a gasket under boost, you'll eath the gasket ( cheap), might ruin the head ( not that expensive to fix), but the iron block won't be as likely to be hurt (compared to an alu. block, which would be expensive to replace). plus in my opinion, they can handle a bit more heat than an alu. block and you could bore it out if you ever wanted to.
Old Jan 24, 2006 | 07:07 AM
NA$TY-TA's Avatar
ahhhh its all good.............
I went with Iron for strength...... if i ever change Motors ill go back to a Alum. to save the added 90lbs the iron block added......
Old Jan 24, 2006 | 08:18 AM
1dirtyZ's Avatar
heheheh, same thought here !
Old Jan 24, 2006 | 08:37 AM
NA$TY-TA's Avatar
Yeah it is..... trying to find weight in other area's is hard ha ha damn PIG LOL
Old Jan 25, 2006 | 11:35 AM
pontiac's Avatar
I so I knew it was stronger I asked how much???????????????????
thanks
