Avalanche manifolds?
Old Jan 30, 2006 | 07:38 PM
Boss man's Avatar
Default Avalanche manifolds?
In the market for some truck manifolds for a custom turbo build up and I ran across these. This setup will be for a 1969 camaro, how would a set of manifolds like these work out? I would imagine the dimension of them to be somewhere close to the stock cast?
http://cgi.ebay.com/ebaymotors/OBX-H...QQcmdZViewItem
Anthony
Old Jan 30, 2006 | 08:25 PM
White.Lightning's Avatar
I am running a set of 5.3 avalanche cast mani's. I would assume they are a direct fit header implying that they could bolt up to a stock exhaust on an avalanche. Mine are off a 2003 5.3 motor.
Good luck
Andy
Old Jan 30, 2006 | 11:32 PM
FastKat's Avatar
Is fitment any different than the regular 5.3L/6.0L truck manifolds?
Old Jan 30, 2006 | 11:35 PM
Revolutionary's Avatar
I would defintely use the 6.0 mani's for the turbo setup. I have seen some pretty hard times on a couple of them with boost and they glow red and don't break for dead.. that's what matters.
They are becoming more readily available watch ebay for em
Old Jan 31, 2006 | 05:49 AM
smokinHawk's Avatar
those tubular wont fit on a fbody (93-02 with ls1) forward facing with out modifing the tubes or steering shaft.
not sure on your 69
Old Jan 31, 2006 | 06:21 AM
There are a few cars on here running the 4.8 and 5.3 truck manis. Stenod runs 8's on their white formy. I dont see myself having any trouble with the 5.3 ones.
I matched the 5.3 avalanche cast manis to my 6.0 heads and they line up perfectly. I am going to port match them and the heads to the gasket.
Good luck
Andy
Old Jan 31, 2006 | 03:29 PM
FastKat's Avatar
I think they're all the same truck manifolds... 4.8's, 5.3's, 6.0's... whether it's off an Avalanche or a Silverado or any other truck.... right?
