Rearmount people IN!
Old Feb 1, 2006 | 08:01 PM
fletchls1's Avatar
Default Rearmount people IN!
I am in the process of putting in new headgaskets/clutch/flywheel and updated slave... I have been told that with the mods that I have done to my car to only run 8lbs boost...How much pwer are the rearmounts putting out at 8lbs?
Second question: Since I will have her all tore apart, what other mods can be done to gain the most amount of pwer without busting my bank account?
Old Feb 1, 2006 | 08:03 PM
NoGamesLS1's Avatar
Go with 6.0 heads to lower compression. And maybe a thicker head gasket.
Old Feb 1, 2006 | 08:17 PM
JAvenger007's Avatar
if you havent already consider some 918 springs, rockers, hardened pushrods and like said above, some LQ9 heads. Then if you wanna spruce it up check out maybe a LPE GT7 cam. Hows it sound with those LTs and !cats
Old Feb 1, 2006 | 08:24 PM
fletchls1's Avatar
I have a cam in it that was custom ground for a turbo setup and got springs with it...I always thought that heads were not as important with a FI setup do the the air being pushed into the engine..
My buddy had a borla exhaust on his 99 ss and it sounds identical to that. (good i think)
Old Feb 1, 2006 | 08:47 PM
NoGamesLS1's Avatar
The reason you want to go with the 6.0 heads is not because of better flow but bigger combustion chamber. That means lower compression allowing you to run more boost
Old Feb 1, 2006 | 09:12 PM
fletchls1's Avatar
so say i put the 6.0 heads on and keep everything else the same...how many more lbs would these allow me to run?
What is the hp/lb on a rearmount?
Old Feb 1, 2006 | 09:14 PM
NoGamesLS1's Avatar
Im not sure about that, but here is a good way to find you compression ratio with different setups. http://www.diamondracing.net/cocalc.htm
Old Feb 1, 2006 | 09:24 PM
NYSS Guy's Avatar
I had the stock cam, and completely stock valvetrain. I ran 8 psi, and put down 475 rwhp. BUT, your 42# injectors are not going to allow you to make much more than that. I was around 90% duty cycle on my 42's at that point. With enough fuel, you should be able to put down well over 500 rwhp. Good luck.
Old Feb 2, 2006 | 06:33 AM
OUTLAWZ RACING's Avatar
4.10 gears on FI with a T-56?? is this good? i have be told not to do it and a fidanza fly wheel is great help my car spool faster less weight on the rotating assembly and i would spring for so 60# fuel injectors just in case the boost bug bites not sure about the gaskets or heads
Old Feb 2, 2006 | 09:11 AM
fletchls1's Avatar
Just getting 60's, you think I would be able to run more boost saftly?
Havent had a problem running the 4.10's and t56 so far(short amount of drive time) why would it be bad?
I found some 6.0 heads at a decent price, right now im just wanting the biggest bang for a buck since i just dropped a couple grand on other upgrades.
Old Feb 2, 2006 | 09:16 AM
ThaLS1KidII's Avatar
Good sugestions so far, but I also recommend Cometic head gaskets. Some people love them some hate'em. I like them and run them on my rearmount car.
Old Feb 2, 2006 | 09:37 AM
fletchls1's Avatar
Thats what I was running before one blew. I was told the best to get for boost was a gm 3 piece...thats whats going in now.
Old Feb 2, 2006 | 09:47 AM
longrange4u's Avatar
I hate to say this... but use search. I personaly have had three threads tha would have all this info in it for you... Let alone everyone else. In the last month there has been TONS of info on rear-mounts.
Old Feb 2, 2006 | 10:12 AM
Zombie's Avatar
My car had 4.10's when I got it, after switching the 3.42's the car was faster.
Old Feb 2, 2006 | 10:27 AM
fletchls1's Avatar
Zombie- why would switching to 3.42's make it faster? wouldnt 4.10's help with spool up? a4 or m6??
Old Feb 2, 2006 | 11:57 AM
venom346's Avatar
Default ..
Turbos work off load, the more load the car get the hotter the ehaust gas temperatures get, which in turn spool the turbo. the 4.10's wont load the car as much as the 3.42's would.
Old Feb 2, 2006 | 12:57 PM
Zombie's Avatar
Now that i'm auto i'm converting from 3.50's to 2.70's to help with drivability. Turbo cars love load.
The car just didn't seem to go very fast with 4.10s, I never ran it at the track with 4.10's, but I have with the 3.42's and 3.50's. With the 4.10's I would have been using 5th by the end of the 1/4.
Old Feb 2, 2006 | 01:08 PM
I couldnt imagine shifting through the gears if I had 4.10's... 1st wouldnt last the first 60'
Old Feb 2, 2006 | 11:10 PM
Scott(382-$T$)'s Avatar
I myself have 373 gears and i know that they are wrong for my car. I am either going to go with 342 or lower
Old Feb 3, 2006 | 08:29 AM
fletchls1's Avatar
what gear are you guys wanting to be in at the end of the 1/4? Before the turbo i was at the very end of 4th and yes sometimes had to hit 5th....
would lower gears (more load) effect dyno results?
